| Posted by hj on November 01, 2002 at 07:58:25: | |
| In response to Re: dura-flo re-piping | |
If this is for a drain pipe, then it can be done, if necessary. It would not correct any functional problem with the pipes, such as sags, but could prevent root invasion if it is done properly. If this is for water piping, it will not work. : Do you have an opinion re: the duraflo system in which the pipes are flushed out, cleaned and then sealed from the inside with epoxy? Is it safe? is it reliable? : Thanks,
| There are none. |
