Followup: Plumbing a New Bath (copper lines and venting)
Posted by Rob on October 30, 2002 at 07:19:37:
In response to Followup: Plumbing a New Bath (copper lines and venting)
: Terry, Thanks for the response about the joists notching. A plumbing book I bought said that notches are okay if you notch only the end 1/3 of the span for joists. But to avoid the whole issue of multiple solder joints and joists notching, I could run flexible copper tubing through the center of the joists, would you recommend this approach? Thanks, Rob
