Leaking Pipe from Sump Pump
Posted by Daniel Fleck on October 28, 2002 at 11:47:54:
I have noticed an area in my lawn that has *very* green wet grass. I'm thinking this is due to a leaking underground pipe. However, the only pipe that looks like it's headed in that direction is the 2-inch CPVC pipe from my sump pump in the basement.
I wouldn't think it would have any water constantly coming out.
What would the downside be to having a cracked pipe leading out from the Sump Pump? Is there any way to verify this is the problem (other than digging up the yard?).
Is there anyway to fix it without digging up the yard?
Thank you very much for your advice.
Replies to this post
There are none.
