| Posted by hj on October 25, 2002 at 09:06:48: | |
| In response to Re: Vent Away toilets | |
Did you also replace the gasket on the Vent-a-Way opening? If not then you are not creating the siphon that is required for a proper flush. And if the new gasket is too thick the same thing can happen because the V-a-W gasket is not sealing. : My American Standard vent away toilet was leaking so I replaced the bolts and put a gasket in the center. After I put the tank back, it doesn't seem to flush completely though I've never had this problem before. What did I do wrong?
| There are none. |
