| Posted by hj on October 25, 2002 at 09:05:03: | |
| In response to Re: Vent Away toilets | |
Did you also replace the gasket on the Vent-a-Way opening? If not then you are not creating the siphon that is required for a proper flush. : My American Standard vent away toilet was leaking so I replaced the bolts and put a gasket in the center. After I put the tank back, it doesn't seem to flush completely though I've never had this problem before. What did I do wrong?
| There are none. |
