Re: Reverse Polarity at Electric Dryer Outlet
Posted by hj on October 25, 2002 at 09:03:10:
In response to Re: Reverse Polarity at Electric Dryer Outlet
An electric dryer cannot have reverse polarity and still work, (and not blow the breaker when the dryer is plugged in). And its outlet cannot be tested with that device. A standard outlet, such as for your washing machine, can have reverse polarity, (meaning the black and white wires are connected to the wrong sides of the outlet), and still operate. The problem would be if the white, neutral, connection in the unit was also connected or shorted to the ground somewhere but the outlet did not have the third, ground terminal in it, in which case the shell of the appliance would become electrified and could cause a shock or death. If the outlet did have the third terminal and this were to happen, then the circuit breaker would trip as soon as the appliance was plugged in. So, if it is really an electric dryer and it works you have no problem. If it is a gas dryer and the wall plug has reverse polarity, use it until your electrician can get it fixed. If the power is on, however, many inspectors use a device s
Replies to this post
There are none.
