Re: Low water pressure problem
Posted by hj on October 24, 2002 at 21:40:04:
In response to Re: Low water pressure problem
A pressure boosting pump will only help if the problem is the city water pressure. If you inside lines are plugged, the pump will not provide any more pressure than the city would supply. And if the pipe to the house is getting plugged, then the pump would cavitate from inadequate supply and destroy itself.
: I recently moved into an old home (built in the 1890s)and have found that I can't have more than one water-related thing on at one time because the water pressure wanes to almost a trickle. This includes everything - shower, sinks, washer, flushing the toilet, and spicket/hose outside. This has become increasingly annoying, mostly because I'd just like to know what the problem is. Before I moved in, the previous owner told me that it was due to an old main water pipe to the house; my inspector told me it was probably due to non-copper pipes in the walls. Unfortunately, I know nothing about plumbing and in my quest to get educated before I call anyone, I stumbled across this site. I'm hoping I can get some good suggestions on what to look into next.
: Not sure if this info helps but- With just one thing on, the water pressure is fine. In my basement, I can see the pipes going to my downstairs bath, kitchen, and washer. They are all copper. My water bill says my meter tap is 3/4 (at least I'm guessing that's what the 3/4 refers to). My neighbor says her pressure is great - she can shower and run the washer at the same time, no problem. Someone in my office suggested installing a water pressure pump. Anyone have any suggestions?
Replies to this post
There are none.
