| Posted by Casman on October 23, 2002 at 12:53:48: | |
| In response to Re: Humidifier Maintenance | |
: When removing the cover to the humidifier that is attached to my gas furnace, I discovered a dead bat inside! : Any idea how he ended up there??? Yup, my guess is that you have an older home in an area with bats. The critters flew into your chimney, then crawled down in through the ductwork venting from furnace to chimney, and ended up in the humidifier. They almost always travel in pairs. A chimney cap can fix this and you should have a thorough inspection of the attic chimney area to rule out a colony of bats which if found should be evicted..... |
| There are none. |
