Re: Toilet doesn' t flush all the way
Posted by Terry Love on October 21, 2002 at 13:18:51:
In response to Re: Toilet doesn' t flush all the way
 Bob, I would guess that there is something stuck in the trapway of the toilet. Sometimes you can remove it by plunging or snaking. If that does not work, you may have to remove the toilet and pull the blocking item out from the bottom. If the blocking item is stuck at the top of the trapway, that's a bit tougher. Since the toilet rocks back and forth, you may need to find out why the bolts are not holding it down to the floor. The bolts need to be firm, and shims can be used where the floor is not level. Sometimes, the plastic horn on the wax can prevent the toilet from setting down on the flange.
Replies to this post
There are none. |
