| Posted by Joel on October 17, 2002 at 17:23:30: | |
| In response to Re: stuck valve on radiator | |
: We bought an older house that has radiator heat. Some of them work well, but in others the valve that opens and closes the water is stuck. Any suggestions? Juan, Replace the stuck valves with new units. After you have turned off your heat and depressurized the system (this can be done at the boiler - there should be a guage on it), remove valve with wrench. Install replacement, wrapping threads with teflon tape. Here are some pointers: Good Luck! |
| There are none. |
