| Posted by Steven Kahler on October 15, 2002 at 11:57:40: | |
| In response to Re: Installing a Bathtub/shower in a bathroom | |
Probably the best way to gain access is to rent an electric jackhammer. Your local rental/hardware store should have one they can rent, and it shouldn't be too much money. They rent for about $10.00 an hour. If you want to install a Tub rather then a shower, then mark where the drain from the tub will be on the concrete, in relation to where the actual drain is. With the jackhammer, you will need to trench that distance, and I would make the trench 6 to 8 inches wide, and 10 to 15 inches deep. (remember, you are going to have to get in there to work with the drain pipe). Once you have attached the drain, you should get in there and fill the hole with concrete again. I hope this helps. Steve
| There are none. |
