This is a newly constructed house with underfloor radiant heat. my 2nd floor toilet is installed very close to the DWV stack and the plumber installed a flange that imediately starts to bend right under the flange. Also one of the heat tubing is running very close to the flange. I cannot use a nonwax (fluidmaster) seal so what the heck do i do now? The plumer is gone away and the nearest plumber is 80 miles away also supply stores. I need to know what to ask for in a nonwax gasket that will work in this situtation. I have asked at several shops and they just shake thier heads and no answer, there must be a product out there that will work HELP.
