| Posted by Terry Love on October 13, 2002 at 00:38:06: | |
| In response to Re: Mixing PEX and copper OR redo completely with PEX | |
![]() Martin, Deciding between a manifold system or a standard pipeing layout, is choice too. Either way, it should be fine.
: I like the idea of using PEX because I have no experience with copper. Currently the plumbing is all copper inside the walls and it seems to be in good shape. : My question is: : wherever there is existing copper plumbing close to new fixtures (typically with 5 feet) should I: : divert the copper lines to the new fixture with PEX? : divert the copper lines to the new fixture with NEW copper? : completely redo all lines with PEX from a new manifold and using home-run circuits? : Access is not a big problem since this is a 3-story house and most work is on the 2nd and 3rd floor. I will be removing lots of drywall and floor sheathing anyway. Most plumbing is on the 2nd floor and I have easy underfloor access from ground floor unfinished storage rooms. I was thinking of putting a new Vanguard manabloc manifold in the utility room on the ground floor.
| There are none. |
