| Posted by Larry on October 10, 2002 at 01:33:57: | |
Is there anything you can use to glue or stop old cast iron radiator leaks from a small hole? Spmetimes the hole is in a place that one cannot drill and screw in a plug. Buying the cast iron floor models do not emit the same amount of heat. Thanks. |
| There are none. |
