| Posted by hj on October 08, 2002 at 23:45:55: | |
| In response to Re: iron vs. plastic | |
You cannot cut it with a cutting torch. All you will do is melt it and have an end that will not be usable with any type of joint device. : I'm moving some plumbing aorund underneath my house and have shorten some of the sewer pipes. Should I just cut down the old cast iron and reuse it (yes, have cutting torch available) or should I replace the full length with plastic? : Thanks,
