| Posted by hj on October 08, 2002 at 09:05:25: | |
| In response to Re: shower with single control mechanism | |
ALl the new pressure balanced shower valves come with an adjustable temperature limiting stop in the handle. I do not use the PP valve, so I cannot give you exact instructions for it, but normally you remove the cap from the handle and inside is a two piece plastic cam that you remove the outer piece and rotate it to the position that allows the handle to move further into the hot range. : I've put a new bathroom in my house and in the shower I installed a Price Pfister single control shower. Now that all the finish work (tile, paint, etc.) is done I've turned on the water supply and can only seem to get the shower to be luke warm at best. : Any comments or advice would be greatly appreciated. : Thanks
| There are none. |
