Re: Pedistal sink install questions
Posted by Terry Love on October 07, 2002 at 12:34:51:
In response to Re: Pedistal sink install questions
: I am going to install a pedistal sink and I noticed that underneath the vanity that I have, there is a roung plastic cap with a square on the the top of it. It looks like the square is there in case you need to unscrew it with a crescent wrench. I want to install the sink but I see the round cap and the hot and cold shut offs and I was wondering is there a way to hide all of this because the neck of the ped sink is so small that it would be inpossible to hide these things behind it, especially the round cap. Am I able to remove it? Also, I need to tear down the existing vanity and I was wondering if you had any do's and donts because it is attached pretty good to the wall.
Jerimiah,
The square plug is for the cleanout. I would leave that there for future work on your plumbing.
The shutoffs, will need to be left for supplying water to the lav.
The old cabinet is most likely screwed to the wall studs. I'm guessing you will need to do some drywall repair when finished.
Since you will be doing drywall repair, consider installing some backing for the bolts or screws that hold the new bowl to the wall.
There's nothing worse then empty wall when you want to secure a pedestal lav to the wall.
Replies to this post
There are none.
