Re: spigot extend
Posted by hj on October 07, 2002 at 08:54:27:
In response to Re: spigot extend
That can be done, and I am assuming you would install the PVC piping underground. The problem with this method is that in the future when that faucet requires replacement, the connections might be difficult to remove, and the angles to line up the connection to the new faucet would probably be wrong.
: I am not sure if this is the correct board for this question but here it is.
: I need an easy solution.
: I neet to run water to 3 sections of my property that are 100 to 250 feet away from the nearest spigot
: Would it work fine to just put a "Y" spliter on a spigot and run PVC pipe off of one of the "Y" ends to each location,?
: Thanks for any help
Replies to this post
There are none.
