| Posted by Terry Love on October 01, 2002 at 22:58:28: | |
| In response to Re: Complete flush requires holding down the handle? | |
![]() : To completely flush my 2nd floor toilet I must hold down the handle for about 10 seconds or else the flushing action looses momentum and stops. But, my ground floor toilet doesn't have this problem - it flushes normally with just a quick press of the handle. I checked inside the 2nd floor toilet tank and it looks like the rubber drain stopper is prematurely closing up the drain hole. Is there anything a novice like me can do to correct this inconvenience such replacing a part, etc? Russ, Most newer toilets do not use all of the water in the tank. Only a portion of the water is used during the flush. The rest is used to mantain a higher "head pressure" in the tank. By stacking the water higher, more pressure is built. If you mean that the flush is not flushing away everthing, then perhaps you have a replacement flapper that has not been trimmed right. |
| There are none. |
