| Posted by hj on September 26, 2002 at 00:11:43: | |
| In response to Re: Autocirc | |
If you installed a backflow device the Auto Circ, and others like it, would not work. They are not a perfect solution, since the unit will stop circulating when the temperature reaches 100 degrees, otherwise you would fill the cold water piping with hot water, but they do help quite a bit. : I am interested in the autocirc act-303-btw retrofit : http://www.lainginc.com/act303.htm : Is there a problem uses this, because it seems to me : Thanks
| There are none. |
