| Posted by hj on September 25, 2002 at 00:15:04: | |
| In response to Re: What are likely locations of leaks in plumbing of old hot-water heating system? | |
Rather than check for problems after they occur, it may be better to repipe the supply for the heating system directly to the point where the water supply enters the house. The put a ball valve on the line that supplies the house and turn that off, and drain the water lines, but leave the supply to the heating system on. : In thinking about how to best protect our 1906 Wisconsin house during an extended winter absence, : If I can identify such points, then perhaps I could install a water-sensing automatic shut-off : I want to maintain limited heat in the house during our absence to protect the structure and furnishings. : Does anyone have suggestions about the best locations for the sensors? Suggestions about this
| There are none. |
