| Posted by hj on September 25, 2002 at 00:11:29: | |
| In response to Re: Bathroom faucet installation problem | |
If they are referring to the flexible connector pipes, those pipes are labeled for use only in accessible locations, not in a wall. : We are replacing faucets. I found one (PF)with a single lever that will fit 4" center holes previously used for 2 levers. It has water supply lines already soldered to the housing but they are too short to reach our water supply. I was told at local home supply store to get some lines that will work as a patch line to the supply source.
| There are none. |
