| Posted by hj on September 25, 2002 at 00:07:50: | |
| In response to Re: venting | |
It depends on where you live. If it is in an area that has freezing weather in the winter, then the exposed part could freeze closed due to the humidity in it. Otherwise, there is no problem other than the appearance. : Can a vent be run through the wall then outside and up, past the roof, rather then through the wall and out of the roof?
| There are none. |
