| Posted by Jim Bean on September 22, 2002 at 18:45:08: | |
Ice maker replaced only to find the problem was rusted and clogged ice maker water line valve and elbow joint(s) where water line is attached to ice maker plastic tube. New valve was installed along with new galvanized elbow joint(s). Possibly, another galvanized elbow was not replaced at the water line valve. One week later still getting rust in small seven cube GE ice maker that only refills about every 75 to 90 minutes. My thought now is to take this plastic tube to the sink or window instead of the ice maker and let the water run through it continuously for about 36 hours in hopes this will clear it up before calling the plumber again, or my attempting to replace one more gavanized elbow bend that I believe is at the ice maker line valve. There is no water rust problem elsewhere in the home. I live in Memphis, TN which has good water. Presently, I am letting the plastic water line run continuously into the yard. The water looks clear. I have two filters that I am considering. The GE Smartwater GXILQ which implies it reduces, Lead Cysts, Chloring, Sediment and Rust. The other is the GE Smartwater GXRTQ which states on the box that it reduces Taste & Order, Chlorine, Sediment, Rust, but within the booklet it appears to state only that it reduces chlorine which is not my problem. Not wanting to fool with changing a filer every six months, I inclined to wait and see if the rust washes out after running the water for thirty six hours, but then with it using only seven cubes worth of water every 75 minutes, I am afraid that even if the water is clear now, that later the ice will again be rusty. I would apprecite your comment on whether it is worth the trouble to fool with the filters and if so, which one.
