| Posted by hj on September 21, 2002 at 21:23:47: | |
| In response to Re: Kitchen sink drain line | |
Measure the disposer from the flange to the center of the drain outlet and then make the drain from the wall 2 or 3 inches more than that below the bottom of the new sink. : I am installing a new kitchen sink deeper than the original sink - How far below the sink should the drain line be? Is there a minimum spec that will allow for proper drainage?
| There are none. |
