Re: Replacing cast iron sewer line in basement
Posted by Gary Swart on September 21, 2002 at 03:00:18:
In response to Re: Replacing cast iron sewer line in basement
#1 You'd never get the plastic pipe fed through the old line. The slightest rough spot or bend would block the new pipe. #2 the pipe would be too small if you did manage to get it through. You're going to have to break concrete and do the job right. Afraid there's no quick, easy fix to your problem. But I think you already knew that.
Replies to this post
There are none. |
