| Posted by hj on September 21, 2002 at 00:29:58: | |
| In response to Re: Offset closet flange - no flush | |
You have a problem but it is not with the offset flange. : I have an old Kohler Rochelle toilet on a 4" plastic waste line. The line is 14" from the wall so the iron closet flange is offset 1.5". The toilet never flushes until the handle is held down and most of the tank empties. Is the rough and rusty offset flange causing the problem (turbulence)? I am remodeling and can furr out the wall 1.5" and chisel the flange out of the concrete and put in a straight one if that will help.
| There are none. |
