| Posted by Ron on September 20, 2002 at 09:31:01: | |
My 30 year + cast iron sewer drain line in my basement appears to be rustng through (Surface cracks and small leaks). Must I replace the entire bad section with new cast iron piping? If I use plastic piping, should I replace the cast iron pipes or can plastic be used as a sleeve for inside I am trying to avoid replacing the cast pipe that exits the house as it passes under a concrete porch Thanks, |
