Re: Delta Model 1700 Series faucet install
Posted by hj on September 19, 2002 at 01:22:52:
In response to Re: Delta Model 1700 Series faucet install
With a fiberglass shower, you can cut a hole just large enough so the escutcheon screws will fit through it and then leave the plaster guard on the valve and clamp the fiberglass between the black plastic ring and the finish escutcheon trim flange.
: Help please!! I'm installing a Delta Model 1700 Series faucet into a remodel fiberglass showerstall. How does this rascal get installed? Do I use the black plasterguard, and cut a hole the same size in the fiberglass or am I reading too much into this? Thanks for any help. Cheers!!
Replies to this post
There are none.
