| Posted by Terry Love on September 19, 2002 at 00:27:34: | |
| In response to Re: Delta Model 1700 Series faucet install | |
![]() : Help please!! I'm installing a Delta Model 1700 Series faucet into a remodel fiberglass showerstall. How does this rascal get installed? Do I use the black plasterguard, and cut a hole the same size in the fiberglass or am I reading too much into this? Thanks for any help. Cheers!! The plasterguard is meant to be even with the finished surface. On fiberglass, I have installed it behind the fiberglass before. Check your finish plate to make sure you don't need it to dish in. There is a bit of plus/minus to work with here.
| There are none. |
