Re: bathtub doesn't drain properly
Posted by Debbie on September 17, 2002 at 14:42:24:
In response to Re: bathtub doesn't drain properly
If I told you we had Quest plumbing, would it be cause for concern?? The bathtub drain isn't clogged, water will go through, but the water doesn't run naturally towards the drain anymore. I don't know if it is a settling problem with the tub or something else. What can I have done if it turns out to be a leaking enclosure?
Thanks for your input and patience.
Replies to this post
There are none.
