| Posted by Gary Swart on September 17, 2002 at 05:13:30: | |
| In response to Re: putting a toliet on to a basement floor | |
Is the drain below the slab? If so, you will have to break the concrete out, attache the toilet drain line, and replace the concrete. There are several requirements and details that go with this. If the drain is not below the slab, then you will have to use a toilet with a pump and that's a whole "'nuther" problem. |
