| Posted by hj on September 17, 2002 at 01:46:14: | |
| In response to Re: leaking water heater | |
That answer is not easy to give and it has nothing to do with your ability. The drain valve may be plastic and you have just as much of a chance of it unscrewing as you do for it to break off. If that happens, removing the stub in the water heater can be a challenge. Once the old valve is removed, it is just a matter of installing a 3/4" brass nipple and a female drain valve. : Could someone advise me if repairing a leaky water heater is within my abilities? It leaks at the drain cock. (I've done a bit of "home plumbing" but have never tackled something like the water heater.) I appreciate any help anyone could lend on this.
| There are none. |
