Repair Cracked PVC Tub Drain
Posted by Chris on September 16, 2002 at 22:55:53:
I removed a section of dry wall to repair a water leak to a shower. After repairing the shower, I discovered the pvc tube drain pipe is leaking due to a stress crack around half the circumference of the drain pipe. Is there anyway to repair this crack without removing the drain pipe?
Replies to this post
There are none.
