Re: Pin holes in hot water pipe
Posted by hj on September 15, 2002 at 22:38:05:
In response to Re: Pin holes in hot water pipe
Electrolysis can be a greater problem if there is an electrical ground wire connected to the hot water piping. It can even destroy a water heater in a matter of months, as one of my customers discovered one morning. : Terry, : I'm noticing a series of pin holes developing along the bottom edge of my hot water pipe. You see a droplet of water & green oxidation on the pipe. For now the drips are minor & could be repaired by replacing the section of pipe. : My question is what will fix the problem "long term". : The pipe in question is an original, circa 1953, but a hot water heater was installed about 5 years ago. I thought it might be a grounding problem, but thought electrolysis was caused by two dissimilar metals? Maybe in the water supply? Why only this one section of pipe? : Any ideas would be appreciated. : Thanks : Russ Romond
Replies to this post
There are none. |
