| Posted by hj on September 15, 2002 at 22:35:51: | |
| In response to Re: pvc sprinkler pipe under concrete? | |
Once it leaves the PVB, the line is yours and you can do anything you want with it. I would question whether you really want a PVC line under or in the concrete where it could break and be inaccessible. : I just finished running a new copper water main to my house. Where it comes up out of the ground there will be concrete for about 10'. I have a pressure vaccum breaker attached to the copper to feed my lawn sprinklers. Is it ok to run pvc from the output of the PVB through the concrete and under the concrete to the lawn?
| There are none. |
