Kohler - AMFAG kitchen faucet with pull-out spray - leak
Posted by Arthur on September 13, 2002 at 10:46:20:
First of all, the base of the faucet unit has Kohler label on it. The pull out spray unit, after removing the rubber cover over the spray pattern selection mechanism, shows "AMFAG". Are/were some Kohler pull-out spray units for Kohler made by AMFAG?
The real problem is the a water leak within the pull-out spray unit. Water is leaking from the end attached to the hose (not from washer either). Water's dripping between the outer casing and the black plastic internals. Back on 12/08/2000, there were two posts on perhaps, fixing this leak, but the posts are no longer assessible, nor retrievable via Search. Anyone fixed this problem and care to share the how?
Thanks so much. Trying to save $60 for a replacement unit from Kohler.
Replies to this post
