Re: Toilet tank leaks
Posted by hj on September 13, 2002 at 08:49:19:
In response to Re: Toilet tank leaks
The bolts are not welded, but we would have to be there to see exactly what the problem is. Generally the bolts either fall out when the nuts on the bottom of the bowl are removed, or they have additional nuts on the bottom of the tank that have to be removed.
: The bolts that hold the toilet tank to the bowl are broken off. The heads of the bolts appear to be welded to the inside of the tank bottom. Can this be fixed in any way, or do I have to get a whole new toilet? Thank you.
Replies to this post
There are none.
