| Posted by Gary Swart on September 12, 2002 at 01:09:56: | |
| In response to Re: noisy pvc plumbing | |
A couple of thoughts. You might box the pipe with plywood then inject foam insulation through small holes. Use the non expanding type. The other idea would be similar, but just use fiberglass insulation around the pipes. |
| There are none. |
