Re: P-Trap alignment
Posted by Casman on September 10, 2002 at 13:59:49:
In response to Re: P-Trap alignment
: Sorry, it's kind of a difficult situation to describe in words. The inlet would be vertical, but the outlet would pass right next to the inlet. I still think "pigtail" is probably the best word I could use to describe it, and the draining water would "loop-the-loop" so to speak. Basically, does the outlet fitting have to be aligned with the trap? Or can it be rotated significantly? 90 degrees? 160 degrees? (180 would be impossible since the inlet pipe would interfere.) In other words, vertical curves are obviously allowed, but can you use the trap fittings to make horizontal turns?
: If you view the crude drawing below in a monospaced font, you'll see what I'm talking about. It should show up correctly automatically in the "comments" box when you submit a follow-up.
: | Drain | [
: F |^^^^^^^|^^^^^^| [W
: R -------\ /------ [A
: O | | [L
: N | |Inlet [L
: T __|_|_________[___To Vent
: / _________________& Sewer
: |-/ |-| Outlet[
: \ \_/ / [
: Trap \___/ [
: : I am not sure I understand your question, but the "P" trap can rotate to any position around the vertical pipe that connects to it. However, the inlet has to remain vertical, so I am not sure how you would install it to not maintain a vertical plane.
: : : Hi,
: : : I'm trying to design a bathroom remodel which involves repositioning the bathtub. In order to get the tub's P-trap to line up with the existing drain branch and vent, I'm tempted to align the trap fittings such that looks more like a pigtail than a "P". In other words, the trap would direct the water away from the wet-wall, but then loop it back towards the wall.
: : : Can I do this? Or does a p-trap assembly have to have to maintain a vertical plane?
Oddly enough, I know what you are saying and the answer is yes.....
Replies to this post
There are none.
