| Posted by Steve on September 10, 2002 at 08:12:29: | |
| In response to Re: How to Replace Overflow Drain Gasket for Tub? | |
I would suggest you look at tub drains and ovwerflows at your local supply or hardware store and see how they go together. Ask them questions. Then proceed. : I've located the cause of a leak from our tub, a defective "crumbling" overflow drain gasket. I've obtained the new gasket... the problem is installing it. The distance between the back of the tub and the overflow pipe makes it extremely difficult to insert the new gasket, and I don't want to "force" anything. The upper section of the overflow drain looks like it can be "detached," but as it would have to unscrew to do so, it would strike the side of the tub in turning, so that wouldn't work.How do I install the new gasket?
| There are none. |
