Re: Leaky Nibco frostproof sillcock
Posted by Sam Borso on September 09, 2002 at 19:21:06:
In response to Re: Leaky Nibco frostproof sillcock
: : <<<<: What needs to be done to repair Leaky Nibco frostproof sillcock? When water is on, it leaks as much around the handle as what comes out of the hose.>>>>> : : : : Mine does this too, I took it apart and there was a crumbly clay-like washer thing...anyone know how to replace it? : I guess I make three...It seems to be getting worse...where can I get the replacement parts? Or is it just a bad product and we should all start over. In order to fix this leaking around the handle, you first remove the screw that holds the handle on to the valve stem. Next, you remove the packing nut - a large adjustable wrench will work. Then you need to remove the old packing gasket material and the brass packing washer. Clean up the brass packing washer and replace the packing washer, if you can find one in the size you need. Look for a flat packing washer in your hardware store. You can also check with a plumbing supply jobber. It doesn't have to be the grey clay-like material that you removed. I searched many stores without success. I fashioned a new packing washer out of 1/8" thick rubber, and it worked fine. Make sure you put some thread dope on the packing nut threads before you re-install it. Don't over-tighten the packing nut; stop when you get resistance. The rubber material will fill the gap very nicely, and the leaking around the handle should have stopped competely. There is nothing wrong with the design of the faucet. The correct order of re-installing these parts is: (1) the brass packing washer (2) the new packing gasket material (3) the packing nut (4) the handle
Replies to this post
There are none. |
