| Posted by hj on September 09, 2002 at 09:46:20: | |
| In response to Re: Water Pump | |
To find the leak may require extensive investigation. The first places to look would be the toilets, then a leaking check valve allowing the water to return to the well, and then the pipe from the well to the tank and any other buried piping. Once the most likely sources of the leak are checked and eliminated then you have to check the entire piping system and faucets. : I am on a well. My water pump is coming on every 5 mins. even though all taps are closed. I am obviously losing pressure somewhere, but am at a loss as to where this may be. The pump itself is 2 years old and this problem has recently started. Everything else is working fine and the pump delivers as much water as is required. Your thoughts on this are appreciated.
| There are none. |
