| Posted by hj on September 08, 2002 at 22:03:57: | |
| In response to Re: Single lever taps | |
Whether they are better depends on the user. But the advantage is that you can adjust the water temperature and flow by moving the single handle. With two handles you have to adjust each of them to get the proper temperature, and then adjust both again to change the flow rate. : Are single lever taps better than a separate hot and cold tap? Why?
| There are none. |
