Craftsman 40/60 shallow well pump
Posted by Richard Rodriguez on September 07, 2002 at 10:35:12:
I have a shallow well pump and bladder tank, which I installed 2 years ago. It has not been used in 6 months. I fired it up yesterday and now there is very low water pressure and the pump won't turn off (I have to turn off the switch). The pressure in the tank is ok, but the pressure on the pump only gets to 22psi - cut-off is at 60psi. Cut-in is 40psi. As best as I can tell everything appears to in order, I've checked the pressure switch and it is where it should be. What do I do now? Thank you in advance.
