Re: Wonder Board
Posted by John Bridge on September 06, 2002 at 18:04:49:
In response to Re: Wonder Board
The plan should be to remove the tile and sheetrock and then install the backer board to the studs over a moisture barrier. We recommend following the manufactuers guidelines.
: What can I use to fasten wonder board to a wall that is covered with ceramic tile over drywall? Would thinset and drywall screws work?
Replies to this post
There are none.
