| Posted by Casman on September 06, 2002 at 09:20:01: | |
| In response to Thanks Again... | |
: There is normally a cover secured by a bolt off to one side. It is a city component so call them to reattach the cover. There is a valve down there but you do not have a wrench to turn it, and some water companies take a dim view of people turning it off anyway, since it can be expensive to repair if it is busted. Depending on your area is platted, anything within a certain distance of the street centerline, often 30', is city property. : : Hey, part 2, water meter is in basement, this curbstop thing, should it have a cap on it or what, as of now it just looks like a vertical pipe flush with the grass? What is there a valve down in it or what? This thing is 3 feet from the sidewalk , not in the easement, does that matter to whether or not its a curbstop....
| There are none. |
