| Posted by hj on September 04, 2002 at 08:25:06: | |
| In response to Re: Varying shower water temperature | |
It appears to be a varying water pressure problem, but whether it is fixable depends on your piping system. You need a plumber to check it out. From here we cannot determine why the presssure is varying. : I have a shower directly connected to the bath faucet. When you turn it on, it regularly goes from a good temperature to freezing cold to scalding hot again. : Is this an uneven water pressure problem? Is it easily fixable? : Thanks
| There are none. |
