Re: Old Jameco faucet
Posted by Jim Riehl on September 04, 2002 at 02:23:55:
In response to Re: Old Jameco faucet
: Old Jameco dual shower faucet leaks. It requires a one inch +/- dia. female spline tool to service -unless the plastic sleeves surrounding the bushings is cut away.
: Is the tool available?
: Will there be any more surprises?
Check your local plumbing supply store. If you are comfortable with the knowledge and skills necessary to rebuild/reseat an obsolete old piece of junk like that jameco, you're probably better off buying and installing a more modern tub/shower valve, though. the new ceramic disc type valves will never need servicing/replacing and are resistant to mineral build up from hard water and other problems you'll be fighting again and again with that old valve.
Replies to this post
There are none.
