Re: Moen Posi Temp Tub/shower leaking
Posted by Jim Riehl on September 04, 2002 at 02:16:05:
In response to Re: Moen Posi Temp Tub/shower leaking
: We installed a new Moen Posi Temp Tub/shower faucet within the last 4 months and now I find that the tub spout
: has started leaking. It didn't do that in the beginning. I have horrible (low) water pressure, so the water isn't screaming
: to get out of the pipes. Where should I begin looking for the cause? Thanks for your time
if you have a diverter tub spout and there is not enough pressure in your water system to hold it fully closed when you pull up on it, it will drip water from the spout and possibly some water will come out the shower head at the same time. this is normal and the only way to get it to stop is to increase pressure in your system. that means installing a pressure booster pump, replacing obstructed pipes (from mineral build up over time in hard water conditions) or talking your water company into retapping your house water supply onto their main (sometimes the original tap becomes obstructed with minerals or sediment build up). Good Luck! :-)
Replies to this post
There are none.
